Puch filler cap = how many ounces?
Ive been doing 8 filler caps/gallon on the Puch. Does everyone else run that much oil on their Puch? Za50 specifically.
Re: Puch filler cap = how many ounces?
I could be wrong but that sounds like a bit much to me.
I could be wrong but 4 quarts = gallon. and it says 2 filler caps/quart of gasoline. So thatd be 8.
Also, im running a 65cc metra, carb and exhaust. its not stock.
2 filler caps = a quart is what i think it means.
ive been running 1 cap per half gal. on my 80cc and 70cc
on the 80cc i had to run a hotter plug because i was fouling. so i guess im running 25 to 1 with synthetic race oil
A quart is 32 oz., there's no way two filler caps is 32 oz.
Pour a filler cap into a measuring cup and let us know
I didnt say two fiuller caps = quart
I said:
the filler cap says put two caps per quart of gasoline. if four quarts is a gallon, then two caps per quart would be 8 caps yeah?
youre doing 1 cap per half gallon? are you sure? thats a huge difference from my 4 caps/ half gallon.
what are the rest of you guys doing?
yup 2 caps of racing oil per gallon now i am wondering how safe that is.
plug chops were allways fat never lean in fact i was fouling until i went with b6hs.
now i was worried and i put 2 caps per half gallon and my plug is black.
My filler cap has lines that say 50:1 or 25:1
ok first thanks for making this post
i pour four cap fulls of oil into a 50-1 pre mix oil container from the gas station, it says 3.2 fl. oz. 4 caps is close to 3.2 oz just alittle shy but i did spill a bit too.
i tuned my carb now plug chops look perfect! and the motor runs with less engine noise and runs cooler
thanks again for this post
Want to reply to this thread?
