Re: Magnum frame defect???
i don't have a picture, but someone else might post one.
the weak spot isn't really on the swiss cheese motor mount part of the frame, its where the pedal crank goes through the frame on the left side (if you're sitting on the bike.) mine was cracked all the way around the spot where you would slide the pedal crank in.
pictures will explain better. i know its happened to some creatures and others.
i had doug weld mine up and its working just fine.
