Magnum frame defect???
Chris R /
Can someone please point out to me the "weak" spot on the magnum loop frame? I know it has something to do with the swingarm/engine mount area...
I received my Magnum frame via snail mail today and upon opening the box (bunch of corrugated taped together) I instantly noticed that the seller hadn't bothered to brace or cushion the motor mount ears...which of course had shot through the "box" and got bent up to the point at which I'm worried about bending it back without a torch (and a big hairy guy to operate it). I'm wondering if in fact underneath the grease crud if this crack exists or if by bending back the engine mounts it will produce it...
Where does the crack occur?
