Re: 1981 Honda Express 11 na50 carburetor
Dennis /
Thanks for the responses, this web site has been a godsend! So when I remove that drive shaft it will disengage the oil pump all together? Would it be ok to then drain the oil from the oil tank considering it leaks around the cap? Is there anything else I need to keep in mind? Thanks again for all the help!
Dennis
