ZA/ E50 Stator swap?
Ok so i took the za off the brown magnum with all that crazy keyed ignition and that crazyness.
I put an e50 on there.
The wiring isnt quite the same. Same base colors but not stripes.
the za ran and everything worked.
I know the za flywheel goes in reverse, but doest the stator interchange? Cause if it does ill just gun the stator in from the za and call it a day.
Yea, i tried the wiki.
Re: ZA/ E50 Stator swap?
stator plates are the same. when you mount the plate the points should be at 9 o'clock not at 11 like they are on the za
thanks dude
