welding pedalshafts together for pedal clearance?
i saw this idea on some thread.
is it a good or terrible idea to weld part of one pedalshaft to another pedalshaft to create enough pedal clearance to fit a pipe?
is it worth the effort, or is it better off to just bend the crank arm or use spacers?
Re: welding pedalshafts together for pedal clearan
yea you can do that and i've seen it look very nice or, you can add material in the middle and use part of a old handle bar as a spacer.
if you choose the later make sure you grind all pieces to a point and build back up with weld as to prevent breakage.
p.s. it is kinda embarrassing when your fancy custom pedal crank breaks at a rally.
If you are good at metalwork you can bend a pedal crank form a "english bike" to fit. Usually they are pretty long, compared to a moped. If you need one for the right side you will have to remove the gears.
quickest easiest modification ever. works reall well. shouldnt break unless your welds suck.
whats not to like about it.
