restriction.
i know this has prolly been hit 8 cabillajillion times. but. wht r the restrictions on a 1.5 horse puch maxi?
Re: restriction.
Spark plug,cylinder and piston kit, HI TORQUE-CYLINDER head if it has one,clutch for second speed if it is a 2 speed engine,gear box chain SPROCKET,CARBURATOR,THROTTLE SLIDE,JET NEEDLE,MAIN JET,intake manifold,air filter,,EXHAUST PIPE.
Re: restriction.
An easy way to convert your 1.5 into a 2 hp is to put on a 14mm bing and 14mm intake, and drill out your stock exhaust, which can be found in the wiki. Remember to jet accordingly(low to mid sixties). Joe
Re: restriction.
well specifically the air filter but ill try the intake and exhaust.
Re: restriction.
The 2 horse power air filter does not have the ORFICE at each end of the INTAKE TUBE and does not have a plug near where the INTAKE TUBE goes.
Re: restriction.
how do i take this out??
Re: restriction.
In the attacment,you can see the parts that need to be removed from the tube. Also the tube is a larger diameter for the 2 horse power.
Re: restriction.
haha shit mine has none of that. well looks like my exhaust and air filter are both unrestricted. yay i didnt even need to do it myself.
