Re: Rise of the fallen flags?
Saabsonettguy . /
What we need is something completely new. A Fifty cc Honda four stroke type top end with a tunable variator to chain drive setup similar to a derbi. Total engine weight of around 15-20 lbs dry. Two horsepower stock, restricted to meet state guidelines. It could also use a small catalytic exhaust if needed. Then you have a moped that can pass the ever tightening epa requirements for a good long time. Because its 4 stroke there is no gas mixing so its easy for new people, its also cheaper to run. It should do 30 mph out of the box with acceleration and mid range that'll keep up with a modern scooter keeping it safe in traffic. The frame should be steel with a removable fuel tank. Something new and refreshing looking but still keeping to the classic moped aesthetic. No plastic fairings and unnecessary odds and ends. When in bicycle mode the engine should cause no drag on the bike and the pedal ratio should be geared to where it can actually be ridden as a cycle comfortably. Wheels should be spokes with sealed bearings, disc brake in the front and drum in the back. It really makes you wonder why nobody has made one before?
  Rise of the fallen flags?Topic by: Kurt Kurt 07/27/08 01:11AM
  Re: Rise of the fallen flags?Re: Brandon Brandon 07/27/08 01:21AM
  Re: Rise of the fallen flags?Re: Kurt Kurt 07/27/08 01:36AM
  Re: Rise of the fallen flags?Re: ***Kim Jong illest*** ***Kim Jong illest*** 07/27/08 01:41AM
  Re: Rise of the fallen flags?Re: bryanrobo bryanrobo 07/27/08 03:33AM
  Re: Rise of the fallen flags?Re: Andy Andy 07/27/08 05:19AM
  Re: Rise of the fallen flags?Re: elliot in england elliot in england 07/27/08 09:08AM
  Re: Rise of the fallen flags?Re: ben ben 07/27/08 10:43AM
  Re: Rise of the fallen flags?Re: ben ben 07/27/08 11:05AM
  Re: Rise of the fallen flags?Re: M A M A 07/27/08 11:17AM
  Re: Rise of the fallen flags?Re: Jesse -B Jesse -B 07/27/08 11:40AM
  Re: Rise of the fallen flags?Re: Truckerick Truckerick 07/27/08 12:53PM
  Re: Rise of the fallen flags?Re: Mike Scouty McScoutington Mike Scouty McScoutington 07/27/08 01:48PM
  Re: Rise of the fallen flags?Re: ᴛᴇʀʀʏ ᴅᴇᴀɴ ᴛᴇʀʀʏ ᴅᴇᴀɴ 07/27/08 04:28PM
  Re: Rise of the fallen flags?Re: QuickReference QuickReference 07/27/08 04:40PM
  Re: Rise of the fallen flags?Re: Saabsonettguy . Saabsonettguy . 07/27/08 04:50PM
  Re: Rise of the fallen flags?Re: N Wesley N Wesley 07/27/08 05:09PM
  Re: Rise of the fallen flags?Re: Saabsonettguy . Saabsonettguy . 07/27/08 05:11PM
  Re: Rise of the fallen flags?Re: Mike Scouty McScoutington Mike Scouty McScoutington 07/27/08 05:45PM
  Re: Rise of the fallen flags?Re: Eric P Eric P 07/27/08 06:39PM
  Re: Rise of the fallen flags?Re: Kurt Kurt 07/27/08 11:20PM
  Re: Rise of the fallen flags?Re: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 07/27/08 11:27PM
  Re: Rise of the fallen flags?Re: Jaa Bee Jaa Bee 07/27/08 11:37PM
  Re: Rise of the fallen flags?Re: Eric P Eric P 07/27/08 11:43PM
  Re: Rise of the fallen flags?Re: ᴛᴇʀʀʏ ᴅᴇᴀɴ ᴛᴇʀʀʏ ᴅᴇᴀɴ 07/28/08 02:51AM
