Re: 12mm vs 14mm bing
andrewhed /
so think of it this way: the engine is actually designed for a 14mm carb and intake.
it will run with a 12, as the jet in the 12 is made to match the gas/oil mixture to the amount of air passing through the 12mm carb barrel and intake.
14 allows more air, which allows for more gas to be introduced , which means more "juicy goodness" quite literally.
Want to reply to this thread?
