tomos wheels
I need to get a new rear mag wheel for a 2008 tomos sprint. i can only find them on mopedjunkyard but there are two versions 105mm hub and another that is not 105mm. I dont have access to the old wheel to measure it. Anyone know which one comes stock on a new sprint?
Re: tomos wheels
bump... anybody?
Re: tomos wheels
According to my 2008 stock manual the rear break drum is 105mm in diameter. Know anything about putting generic turn signals on one of these things?
Re: tomos wheels
Any turn signal should work. I bought some that were grounded through the bolt. After sanding around the bolt hole a little, they work perfect. I did have to change the bulb though. It came with a 3 watt bulb. Who the heck could see a 3 watt bulb? Check my post "My Sexy LX!" to see a pic of the chrome mini signals I put on.
Re: tomos wheels
anyone know if they are 16" or 17" rims? can i use either size tire or do i have to have the right size?
Re: tomos wheels
Mine say 16. Don't know if you have to have that size.
Re: tomos wheels
Pretty sure Tomoses use 16" wheels, and I would use the right size if I were you. I've never tried changing the sizes to see what it messes up, but why find out the hard way? If you're looking for a good deal, I bet you could find something if you put up a "WTB Tomos wheel" ad in the buy/sell forum.
