Re: 84 Yamaha kickstart for 1$
Nick Jaynes /
Sounds to me like you've got a QT50.
gGet a battery for about $10.99 (to run the accessories) and get an NGK BP4HS spark plug. Check for spark. Make sure you've got oil in the oil tank, that the oil pump is pumping and you've got good gas in the gas tank and that you're carb's clean and she should fire. She'll only start when the ignition is in "start" and won't start in "run." Other than that, it's pretty simple.
For your Puch, wheels can be acquired in the Buy/Sell forum and tires can be acquired from ebay or moped shops...or even local scooter shops.
