Re: Opinion on best carb cleaner?
Matt Smith /
bio diesel
cheep, non toxic. good for soaking.
"Solvency: Biodiesel can loosen or dissolve sediments in fuel tanks and fueling systems. Cleaning tanks prior to biodiesel use may be warranted. At a minimum, fine gauge filters should be used on fuel lines going into and out of storage tanks, as well as in the vehicle. Check these filters often during the initial phase of biodiesel use and change as needed. The solvency effect is reduced when using biodiesel blends. The solvency property of biodiesel makes it an excellent parts cleaner, but avoid contact with painted surfaces.
Material Compatibility: Biodiesel can soften or degrade natural rubber hoses and gaskets, leading to fuel leaks and spills. Most newer engines contain synthetic parts. However, older engines should be checked and any natural rubber parts replaced. Biodiesel is also not compatible with some metals and other materials. Aluminum, steel, fluorinated polyethylene, fluorinated polypropylene, and most fiberglass make acceptable storage tanks. Brass, bronze, copper, lead, tin and zinc should be avoided.
Spills: Spills of biodiesel blends should be treated as a petroleum diesel spill. Spills involving pure biodiesel require much less intensive clean-up. Consult with your local department of ecology or fire department for details.
  Opinion on best carb cleaner?Topic by: gnrle01 gnrle01 07/22/08 12:02AM
  Re: Opinion on best carb cleaner?Re: Jay Jay 07/22/08 12:03AM
  Re: Opinion on best carb cleaner?Re: triumph3434 triumph3434 07/22/08 12:18AM
  Re: Opinion on best carb cleaner?Re: Mike Bartell Mike Bartell 07/22/08 01:39AM
  Re: Opinion on best carb cleaner?Re: M A M A 07/22/08 01:40AM
  Re: Opinion on best carb cleaner?Re: POW POW 07/22/08 02:12AM
  Re: Opinion on best carb cleaner?Re: gnrle01 gnrle01 07/22/08 12:34PM
  Re: Opinion on best carb cleaner?Re: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang 07/22/08 01:50AM
  Re: Opinion on best carb cleaner?Re: James G James G 07/22/08 01:52AM
  Re: Opinion on best carb cleaner?Re: Air Bud Air Bud 07/22/08 01:57AM
  Re: Opinion on best carb cleaner?Re: Zachary Evans, Destroyer of Worlds Zachary Evans, Destroyer of Worlds 07/22/08 02:00AM
  Re: Opinion on best carb cleaner?Re: Aj Aj 07/22/08 02:07AM
  Re: Opinion on best carb cleaner?Re: Graham Motzing Graham Motzing 07/22/08 12:38PM
  Re: Opinion on best carb cleaner?Re: gnrle01 gnrle01 07/22/08 12:42PM
  Re: Opinion on best carb cleaner?Re: Liz H Liz H 07/22/08 12:43PM
  Re: Opinion on best carb cleaner?Re: toe fur threadkiller toe fur threadkiller 07/22/08 01:39PM
  Re: Opinion on best carb cleaner?Re: bx bx 07/22/08 03:13PM
  Re: Opinion on best carb cleaner?Re: Cleats Onionpockets Cleats Onionpockets 07/22/08 03:37PM
  Re: Opinion on best carb cleaner?Re: Justina L2S -+:| Justina L2S -+:| 07/22/08 03:42PM
  Re: Opinion on best carb cleaner?Re: Steve Williams Steve Williams 07/22/08 05:00PM
  Re: Opinion on best carb cleaner?Re: gnrle01 gnrle01 07/22/08 11:08PM
  Re: Opinion on best carb cleaner?Re: JunkyardDog JunkyardDog 07/22/08 06:47PM
  Re: Opinion on best carb cleaner?Re: Mike Alanko Mike Alanko 07/22/08 07:20PM
  Re: Opinion on best carb cleaner?Re: Matt Smith Matt Smith 07/22/08 07:35PM
  Re: Opinion on best carb cleaner?Re: ~ DeeZy ~ DeeZy 07/22/08 08:13PM
  Re: Opinion on best carb cleaner?Re: andrewhed andrewhed 07/22/08 09:14PM
