Re: spark and coil side
bert /
If you're like many owners, you'll get tired of cleaning out the openings in the Gurtner carb with a few strands of copper wire and will end up putting a Dellorto carb on there.
On the right side is the flywheel, and underneath are the points and timing cam. The nut holding on the flywheel is called the Novi nut, and is the source of frustration for many new owners. It loosens to the RIGHT! You can use a 3/8" socket wrench to fo in the opening, but holding the flywheel still is the challenge. Earlier I mentioned getting a piston stop, which is the best way of stopping the flywheel. It works on every variety of moped and is well worth the $10 in my book. You can get one at www.quarterkick.com as well as other sites. They're out of the cam/clutch puller, another inexpensive, but almost required tool for Moby owners.
  just picked up a motobecane...Topic by: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang 07/20/08 10:58PM
  Re: just picked up a motobecane...Re: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang 07/20/08 10:59PM
  Re: just picked up a motobecane...Re: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang 07/20/08 11:00PM
  Re: just picked up a motobecane...Re: Ratty! Ratty! 07/20/08 11:00PM
  Re: just picked up a motobecane...Re: patrick patrick 07/20/08 11:11PM
  Re: just picked up a motobecane...Re: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang 07/20/08 11:40PM
  Re: just picked up a motobecane...Re: Kim Jong illest Kim Jong illest 07/20/08 11:39PM
  here's a picRe: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang 07/21/08 01:21AM
  Re: here's a picRe: bert bert 07/21/08 11:16AM
  variator sideRe: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang 07/21/08 06:21PM
  spark and coil sideRe: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang 07/21/08 06:22PM
  Re: spark and coil sideRe: Shalerrr rrr Shalerrr rrr 07/21/08 06:32PM
  Re: spark and coil sideRe: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang 07/21/08 06:35PM
  Re: spark and coil sideRe: pf pf 07/21/08 06:32PM
  Re: spark and coil sideRe: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang 07/21/08 06:36PM
  Re: spark and coil sideRe: bert bert 07/21/08 06:41PM
  Re: spark and coil sideRe: Mike Alanko Mike Alanko 07/21/08 06:41PM
  petcockRe: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang 07/21/08 06:56PM
  Re: spark and coil sideRe: pf pf 07/21/08 06:42PM
  Re: spark and coil sideRe: pf pf 07/21/08 06:44PM
  Re: spark and coil sideRe: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang 07/21/08 06:51PM
  Re: petcockRe: bert bert 07/21/08 07:19PM
  Re: petcockRe: patrick patrick 07/21/08 09:38PM
  Re: petcockRe: andrewhed andrewhed 07/21/08 10:28PM
  carb is clean.... and was a bitch...Re: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang 07/21/08 10:33PM
