Not sure yet, I need to get an intake made so I can put that carb onto the Malossi quad reed block. The intake that comes with it points straight up into the frame, with 0 clearance to attach anything to it. Need to fabricate a top plate with a hole in it at an angle and bend some copper tubing to bring the carb around to the right side of the frame.
I'm hoping to see max 60mph. It already does 50mph @ 9630rpm with a 16mm SHA and 26/24 gearing.
