time out} Peugeot 103 idles fast
i have a 1o3 that idles fast even when the throttle cable unhook. you turn the idle screw out it don't do anything,then it just shuts off. Thanz for the time to answer this. Dan
Re: time out} Peugeot 103 idles fast
Maybe the throttle barrel thingy isnt going down all the way? look where the throttle cable unhooks. you should be able to see how it connects to a little metal thingy that goes down and connects to where the throttle valve is in the carb. try pushing with your finger down on this and see if the rpm goes down. Otherwise, try taking your carb at least partially apart (theres a little plastic plate held on by one screw that removes the throttle valve) and see if its moving freely.
