Re: tomos lx electrical system?
marvyhi /
Switching out the light bulb to a 12 volt, 1156 bulb will work. The fairing comes off. The bullet headlight goes on and the speedometer goes into the hole on the top of the bullet headlight. Take off the bracket that holds the rectangle light and mount the bullet to the fork mounts. You need to take off the signal lights and disconnect the wires to do this. Disconnect the signal indicator and the high light indicator. You will not have high lights. Connect the headlight wires brown to the ground terminal and the blue to the bulb. The white is for the high light but the new light does not have high lights. There you go. Have fun.
