How? Do i run the engine without oil until i see it coming out to verify its working (which sounds very risky to me) or do i just hook it up and see if my engine breaks or not
and by run with out oil i mean not have the hose connected and watch the end of the hose for it to come out? if i was to remove, how much ratio of oil do i pre mix? for a towny (same engine as qt50)
run some pre-mix in the tank, plug the hle where the oil line goes in the manifold, fill ur lines with oil and start ur engine and observe.
And make sure to either drain the premix before reconnecting the injector, or leave the injector disconnected till you run out of fuel. Otherwise, you'd get a double shot of oil, and you'll foul plugs like crazy.
Connect the carburetor to a small auxiliary fuel tank like a mower tank to test it. Fill your little tank with 40:1 premix and have at it.
