Re: How to build a hybrid moped
dariuskyne /
ok here's how you figure out (simply) the transmission set-up for this hybrid idea, i you have a clutch system on a moped engine already, if you use one like the pulley on a motobecane you can switch it so it's not even engaged.
But instead of driving the rear wheel directly, it would go to a jackshaft, which the electric motor is also chained to, then a main sprocket to the rear wheel, if you get a decent electric motor set-up you can use the electric motor to re-charge the batteries while driving the ped using the gas engine, re-caliming some of the loss due to friction and other laws of physics, untill you can get somewhere to re-charge the batteries fully. basically you'd need 2 throttle set-ups one for the gas engine and one for the electric motor like a pentomiter (spellcheck has failed on this one, think dimmer switch) the other drawback is that you'll have to keep the electrics for the electric motor totally seperate and shielded from the regular moped electrics (think huge power spike, blown bulbs are the least of your worries)
the hybrid, other than the fact that by it's nature a moped IS a hybrid, this idea has been kicked around on this forum multitudes of times, use the search function you'll find lots.
  How to build a hybrid mopedTopic by: trickshot63 trickshot63 07/14/08 11:14AM
  Re: How to build a hybrid mopedRe: Zeke Zeke 07/14/08 11:29AM
  Re: How to build a hybrid mopedRe: trickshot63 trickshot63 07/14/08 12:05PM
  Re: How to build a hybrid mopedRe: Zeke Zeke 07/14/08 12:15PM
  Re: How to build a hybrid mopedRe: MadisonMed MadisonMed 07/14/08 12:31PM
  Re: How to build a hybrid mopedRe: trickshot63 trickshot63 07/14/08 12:36PM
  Re: How to build a hybrid mopedRe: Zeke Zeke 07/14/08 01:36PM
  Re: How to build a hybrid mopedRe: Noah Noah 07/14/08 01:25PM
  Re: How to build a hybrid mopedRe: trickshot63 trickshot63 07/14/08 01:42PM
  Re: How to build a hybrid mopedRe: davey davey 07/14/08 01:29PM
  Re: How to build a hybrid mopedRe: davey davey 07/14/08 01:43PM
  Re: How to build a hybrid mopedRe: trickshot63 trickshot63 07/14/08 01:47PM
  Re: How to build a hybrid mopedRe: jack jack 07/14/08 01:57PM
  Re: How to build a hybrid mopedRe: trickshot63 trickshot63 07/14/08 02:00PM
  Re: How to build a hybrid mopedRe: trickshot63 trickshot63 07/14/08 02:02PM
  Re: How to build a hybrid mopedRe: MadTownMick MadTownMick 07/14/08 06:26PM
  Re: How to build a hybrid mopedRe: Alex Alex 07/14/08 02:29PM
  Re: How to build a hybrid mopedRe: elliot in England elliot in England 07/14/08 04:43PM
  Re: How to build a hybrid mopedRe: Noah K Noah K 07/14/08 06:52PM
  Re: How to build a hybrid mopedRe: JunkyardDog JunkyardDog 07/15/08 03:43AM
  Re: How to build a hybrid mopedRe: Aj Aj 07/14/08 04:56PM
  Re: How to build a hybrid mopedRe: Brian Solex Brian Solex 07/14/08 06:01PM
  Re: How to build a hybrid mopedRe: buckswilde buckswilde 07/14/08 06:17PM
  Re: How to build a hybrid mopedRe: JunkyardDog JunkyardDog 07/15/08 03:07AM
  Re: How to build a hybrid mopedRe: Brian Solex Brian Solex 07/15/08 07:32PM
  Re: How to build a hybrid mopedRe: oFace Killah oFace Killah 07/14/08 06:21PM
  Re: How to build a hybrid mopedRe: elliot in England elliot in England 07/14/08 06:43PM
  Re: How to build a hybrid mopedRe: MadTownMick MadTownMick 07/14/08 07:12PM
  Re: How to build a hybrid mopedRe: MadisonMed MadisonMed 07/14/08 07:18PM
  Re: How to build a hybrid mopedRe: Aaron SE Aaron SE 07/14/08 11:38PM
  Re: How to build a hybrid mopedRe: Eric P Eric P 07/14/08 11:51PM
  How to build a hybrid mopedRe: sojudave sojudave 07/15/08 12:32AM
  Re: How to build a hybrid mopedRe: trickshot63 trickshot63 07/15/08 01:16AM
  Re: How to build a hybrid mopedRe: dariuskyne dariuskyne 07/15/08 09:58PM
  Re: How to build a hybrid mopedRe: trickshot63 trickshot63 07/15/08 11:00PM
  Re: How to build a hybrid mopedRe: fastone fastone 07/17/08 02:31PM
