Re: Ok, figured it out for real this time.
Noah K /
Make sure you line up the opening in the rings with notch and make sure the rings are right side up in regard to the notch. Put some two stroke oil on the rings and piston. Compress the rings as much as you can and hold the piston straight as you slide the bottom of the head on. For putting the rings on the piston a ring tool would help. Generally, be careful about straining the rings because they are brittle.
