Re: Daelim Trac Model Type?
patrick /
That is a Trac Hawk with a M-56 engine. As long as the belt and the air filter do not break,and the breaker points do not wear out, you are set.You may want to make a piece to hold the exhaust manifold on the cylinder if it comes loose or just be aware it could fall off. They are the poor persons Puch Magnum.
