Removing rear fender from Magnum
Seen a lot of Magnums minus the rear fender. Would you just forgo brake & tail lights? Are there any small format brake/tail lights available that could be connected to the existing electrical feed...maybe mounted into the rear of the seat, where the storage compartment is?
Re: Removing rear fender from Magnum
I mounted my taillight in my trunk, it's pretty ghetto but it works.
I'm thinking of building a trunk plate cover with a bunch of LEDs glued in it as a taillight.
Vlado vlado /
I got one from denniskirk.com
look at HD lighting-tailights; there are some expensive and cheap too, cateye w/plate holder was my pick-16.99+S&H
mount your license plate off of your rear axle, and put your tail light on there.
