Express has no lights
Tonight i was riding and i noticed that i had no head light then i stoped and i looked and i had no tail light i checked my turn signals and they didnt work either. The horn comes on just barely and sounds like it is choking. The brake light comes on but thats the only thing that really works. What could this be?
Re: Express has no lights
if you have you head lights on and you but on the brake dos the brake light go off
The head light doesnt even come on at all the tail light stays off untill i pull the brake.
when you have the head light switch on will the brake light still work win you put on the brakes im just trying to see if theres a short
check your ground cable....the white wire right above the engine, under the carb.
Someone told me when one light goes out, most of the lights blow out.
I turned on my headlight right as i started to accelerate, and it stopped working. ever since then only my right turn signal works.
