Keep or return DMP pipe
Is this normal? I just received this DMP pipe for my Puch. The plate that the muffler is bolted to seems to have been welded at angle. Therefore, the muffler/silencer does not make contact with this plate once it's bolted on. I will post a couple of pictures so you can see what I mean because my description is pretty shitty. It is mounted flush with the plate for <50% of it's circumference, and then gradually separates over the remaining portion.
I don't want to use the pipe and then have to try and return it used because it's leaking smoke or not supply enough back-pressure. What do you guys think...not a big deal, is it normal or could it be problematic.
Thank you all.
Re: Keep or return DMP pipe
Did you get one of the pipes made for kits with angled exhaust ports? If so, sell it to someone else who can use it.
Want to reply to this thread?
