5 stars
Is it an easy conversion to put sealed bearings into a set of 5 stars. My front axle is slightly warped and it seemed like I should just replace all the guts so......
Re: 5 stars
Pretty sure 5 stars come with sealed bearings.......
....someone want to correct me if I'm wrong?
Re: 5 stars
should already have em
Re: 5 stars
My 5 stars have sealed in the back, cup and cone in the front. I have a set of sealed bearings and a spacer to put in the front when the time comes that I need them.
Re: 5 stars
I just did the repacking on mine it kinda sucks to do . the rear is sealed and the front are loose . I have some of the cones and stuff if you run into trouble .
Re: 5 stars
getting the tightness right sucks, sealed is where its at. whered you get your spacer from sue and did you need a shim? and have you tried it with anyhting other than a front 5 star?
Re: 5 stars
creature paz had this done I believe.
Re: 5 stars
if you want it professionally done, motomatic mopeds will do it. they did mine and i swear to god my front wheel spins for 3 minutes if i give it a goop push up on the kickstand.
Re: 5 stars
How do you get in touch with those guys?
Want to reply to this thread?
