Re: chain tension
Miguel Centellas /
too loose, you could throw your chain. too tight, it could break. both are bad.
i would actually recommend getting a brand new chain if your chain is old. the chain might be loose because of stretching after thousands of miles of use. a new chain might help quite a bit.
the chain tensioners should be even, because you want your rear wheel aligned properly. otherwise you could run into serious problems.
  chain tensionTopic by: Nick Nick 08/27/02 08:13PM
  Re: chain tensionRe: dave dave 08/27/02 08:54PM
  Re: chain tensionRe: Nick Nick 08/27/02 09:12PM
  Re: chain tensionRe: dave dave 08/27/02 09:29PM
  Re: chain tensionRe: Nick Nick 08/27/02 09:40PM
  Re: chain tensionRe: Miguel Centellas Miguel Centellas 08/27/02 11:27PM
