Re: rear wheel spinning when idling
if it changes, its probably an air leak. if it snot an air leak, and it isnt changing too much, your throttle cable might be too tight. the idle screw governs how much air passes through the carb when at idle by keeping the slide from closing the intake completely. if theres an air leak somewhere, that adjustment is worthless.
