ball peen hamer repair
my a3 bullet had me pissed new condensor new coil new plug good conections clean switch clean points no spark. so off with its magneto and the next thing i know i was holding a hamer and now i need new electrodes new bass plate points and condensor and try to clean the treads up on the crank shaft after i did this i took a closer look and saw that one black wire had very very slightly rubbed the plate. the moped gods are ashaimed
Re: ball peen hamer repair
I see from your profile that you're in South Carolina.
Any chance you just moved there from Jersey?
;o)
You need to discover the healing of hemp next time before you go retard on your ped.
Never hit a shaft end with a hammer. It is impossible to control where it hits and at what angle. If you do not have the proper tool, back the nut off until it is flush with the end of the shaft, place a piece of steel against the shaft and nut, and hit the steel with the hammer.
This way you will get a square hit and you will not screw up the threads.
coricidin /
you know alot of people ask me that but no born in camden south carolina
stop using the corocidin cough and cold. Thats what it does.
