OIL RATIO
ERIC WOOLF /
What is the proper oil to gas ratio for my 78 sears pinto with an e-50 motor? I sure this has been asked many times, sorry for the repeat question.
Re: OIL RATIO
Do a search on this subject. You are correct the question has been asked many times.
Re: OIL RATIO
The tank on mine says 50:1, but some people will say 40:1, some people might run something in the middle, and some people running crazy synthetic oil might even run less oil in their mixture than 50:1. You can check the Murray or Maxi moped manuals at the MRA for info on gas/oil mix, plug gaps, point gaps, torque specs, and all kind of other fun stuff. That site also has a handy gas/oil mix calculator.
Re: OIL RATIO
I would not run more than 3oz to a gallon, which is about 43:1, but 50:1 is what should be used.
