SOmetime my mopoed will go 3mph faster then it usualy does and feels very smoother. It a Arrow with technigas. It is currently having prolblems but it did this before too.
huh?
check to see if you have any leaks, like around the exhaust, or the carb, if theres no leak then idk what to tell you
my moped always runs aorund 35 but soemtimes it will go to 38-39 aboout one every 10 rides or so and its alot smoother
Depends on the weather, temperature, and humidity.
why is this called 3rd gear?
check if your plug wire is on tight .
maybe the ignition has a weak ground .
dirt in the fuel line or filter or carb. could do that also .
Rick
