3rd gear
SOmetime my mopoed will go 3mph faster then it usualy does and feels very smoother. It a Arrow with technigas. It is currently having prolblems but it did this before too.
Re: 3rd gear
huh?
Re: 3rd gear
check to see if you have any leaks, like around the exhaust, or the carb, if theres no leak then idk what to tell you
Re: 3rd gear
my moped always runs aorund 35 but soemtimes it will go to 38-39 aboout one every 10 rides or so and its alot smoother
Re: 3rd gear
Depends on the weather, temperature, and humidity.
weirdo
why is this called 3rd gear?
Re: 3rd gear
check if your plug wire is on tight .
maybe the ignition has a weak ground .
dirt in the fuel line or filter or carb. could do that also .
Rick
