MBecane wheels on a Puch
Would motobecane wheels fit on a Maxi?
I found some wheels online but I cant tell if they would work for a Maxi. I can't tell what kind of Motobecane they're on but heres the link.
http://grandrapids.craigslist.org/mcy/732697008.html
Thanks!
Re: MBecane wheels on a Puch
there's a whole section on it in wiki! yes it can be done i guess!
You can use them. The distance from the drive sprocket to the pedal sprocket is a little narrower, but it works as is. The pedal chain hops a bit but doesn't fall off. You could space the drive sprocket out but make sure you don't destabilize it.
...does this imply that puch wheels would work on a moby...?
Yep:
Spacers are fun, but it can be done.
Anything will work if you think about it for awhile.
