tomos 1991 a35
My brake light keeps blinking on and off while running ,any ideas why this is happening?
Re: tomos 1991 a35
mine does the same thing... not sure why though, so i am interested to find out.
Re: tomos 1991 a35
if i figure out will let you know ,the points may have some rust on them maybe not getting a good contact
Re: tomos 1991 a35
bad connection, somewhere. Start with thelight bulb and see if the contacts are all funky. pull apart and reassemble the spade plugs that go to the light. then check to see if you have any wires that ahve rubbed through their insulation and are causing a short.
Re: tomos 1991 a35
ok,thanks for information .
