connect a stero system to magneto?
i was just watching the hollywood holt vid and i thought it would be sick if i could have my ipod connected to speaker that are generated by the magneto that powers my lights and bump throw a kit really load when i pull up to peoples houses or at a red light. tell em ur ideas thanks
Re: connect a stero system to magneto?
just buy a battery powered bullhorn and yell the lyrics at people. don't even need the ped, just go to walmart and start yelling.
anything to get the word out right? haha
Would not be hard at all. Just connect to your main power line. Could go through the kill swith too on some setups.
I'm not all that great with the wires and stuff like that, i know how to work on the enigine, is there a way to go straight from magneto to speaker
you'd need to convert to 12v.
mopeds are only 6 volt systems. all modern electronics are 12 volt. itd be easier to install a battery to hook up to a speaker than it would be to wire it in.
Tomos are 12 volts, but the magneto doesn't even make enough power for the lights. Puch is even worse. The lights on mine are so dim it is unridable at night. If you overload the lighting coils, you will burn them out. Peace. Jerry.
You want to have a battery that is chargable, and have the magneto charge the battery. The batt will act like a regulator.
mang you gotta hook up like six capaciters to get that 4 inch tweetersub to even play the first beat
just get one of them backpacks with the speakers built in. Use re-chargeable batteries.
The results wouldn't be worth the effort otherwise... I would think any mopeds electrical system would be way too weak to support the extra load for a stereo, unless you completely rewire it to use a battery, etc.
that and the spikes from the electrical system would fry the whole thing
just tape a damn boombox to your ped.
you know you want to.
Tape a Casio on that bitch!
If you only knew boombox Ronny in Kalamazoo...
