'87 tomos choke
chuck-Ohio /
Choke will not open when I turn throttle full open to release it .Any ideas on how to fix problem or release choke?
Re: '87 tomos choke
Kevin Harrell /
The throdle cable is not routed properly. Remove the cable from the carburator by unscrewing the two screws that hold the black part onto the carburator. Their is a return spring that the cable passes either through or around. One or the other. If it goes around the spring then it needs to go through the spring to work. If it goes through the spring then it needs to go around the spring.
