tomos grip?
does anyone know if it is possible to remove the left grip from a tomos? trying to switch out the handlebars and the left one doesn't seem to be removable.
Re: tomos grip?
It's probably just on their tight unless a former owner glued it.
Re: tomos grip?
Pry itup a little then shoot WD 40 .
Re: tomos grip?
have you experienced this problem before? i'm the first owner, so there's no glue involved, and the right grip w/throttle cable came right off, but the left grip won't even budge enough to squirt WD-40 in as far as i can see.
Re: tomos grip?
try twisting and pulling at the same time i got mine off easy
