Re: Greetings
Sara /
Harold - thanks for the speedy reply!
First off -
the mechinic is not a personal friend - but recommened through my employer and other island residents with (not restricting) 2 stroke engines. He was thrilled to see this bike and even told me he would store it inside his limited space shop. :)
My bike does not currently run - the left hand peddle needs a bolt, and is tough to turn. it did run last about 5 yrs ago - then abondoned
the tank does have rust and Kevin (the mechnic) mentioned the same filter - the bike has a small plate mounted on it explaining the feul ratio. I will take your advice on the quality
Thank you thank you thank you for the manual! I will stop in at the seattle store later this week when I am there to pick up my pops from the airport. since main land trips are rare.
  GreetingsTopic by: Sara Sara 06/29/08 03:12AM
  Re: GreetingsRe: Jon P Jon P 06/29/08 03:38AM
  Re: GreetingsRe: Sara Sara 06/29/08 03:43AM
  Re: GreetingsRe: Harold Harold 06/29/08 03:52AM
  Re: GreetingsRe: Sara Sara 06/29/08 04:35AM
  Re: GreetingsRe: Harold Harold 06/29/08 03:55AM
  Re: GreetingsRe: dave j dave j 06/29/08 04:33AM
