Re: I want to shoot my Peugeot frame!!!!!!!!!!!!!!
Al . /
I have cut a 103 frame apart, im not sure if they are all the same, but the one i sliced up had nothing more then a sheet of metal (same thickness as the tank wall) running down the center with rather large circles through it to allow gas in both halves of the tank. If you are going to paint it anyway, sand off the paint, find the holes, fix them (JB weld or flow a little solder into them or whatever your preferred method of repair is) and after they are fixed prime and paint.
