You don't need a regulator if you set the resister so that the current does not exceed the max at max voltage. LED's are quite good at low voltage.
LED's have a reverse voltage problem at about 4 volts. Therefore you need a diode to stop the reverse voltage is you run it off of AC. If you run it off DC, NO PROBLIMO!!!!!!!!!!!!!
Don
