How much MPH would i loose if...
GsxrMatt11 /
How much MPH would i loose if i put one more tooth in the front sprocket???? right now i have a 2001 tomos targa TTLX with biturbo pipe and jetted! i have the stock sprockets
thanx
Re: How much MPH would i loose if...
david f martin /
We can do some math...
How many teeth does your current front sprocket have? How many teeth on the back sprocket? What is your top speed?
Another tooth on the front sprocket should increase your top speed, at the expense of acceleration.
david
if all things remain the same, a larger front sprocket will INCREASE your speed, though you'll lose some acceleration. how much all depends on too many variables (type of engine, carb, jet, exhaust, etc). but if you want more top speed, a larger front sprocket (more teeth) will give it to you.
TJ Miller /
he has a 26 now... he's looking to put a 27 on there...
I have a TARGA LX 1999 with a BULLET exhaust ans the speed sprocket !
The sprocket give me 6 mph more !!
Now i do 40 mph !!!!
