Re: i need some free advice.
Zachary Evans /
Yeah, dustin has a point.
Jetting is more than a number. What you're trying to achieve is an ideal air/fuel mixture.
Too much fuel (which is what happened when you drilled out your jet) will make you bog, or foul plugs, or not run at all.
Too much air (too small of a jet) will cause it to burn too hot. Sometimes you'll go faster running lean, but this isn't what you want. Too much heat and it'll eventually seize, likely ruining your cylinder/piston. This is bad.
So you want to find the perfect balance. You do this by doing plug chops with different jets. Plug chops are easy, but I don't want to explain them here, because they've already been explained very well elsewhere. So your homework is to go find them. Search the wiki, search the repair forums, search the performance tuning forums.
In fact, here. A link : http://www.mopedarmy.com/wiki/Plug_chop
And another good one: http://www.mopedarmy.com/wiki/Fred%27s_Guide
If you post a question, and it can be answered by that second link, then you'll probably either get a bad response, or no response. Everyone should read Fred's Guide at some point.
Wheee.... Coffee makes me type lots....
~Zack
  i need some free advice.Topic by: robby robby 06/25/08 12:10PM
  Re: i need some free advice.Re: Focus Focus 06/25/08 12:25PM
  Clean your fuel filtersRe: Clean your exhaust Clean your exhaust 06/26/08 08:50AM
  Re: i need some free advice.Re: ben ben 06/25/08 12:28PM
  Re: i need some free advice.Re: robby robby 06/25/08 12:29PM
  Re: i need some free advice.Re: N Wesley N Wesley 06/25/08 12:30PM
  Re: i need some free advice.Re: robby robby 06/25/08 12:31PM
  Re: i need some free advice.Re: JunkyardDog JunkyardDog 06/25/08 12:33PM
  Re: i need some free advice.Re: Brian Brian 06/25/08 12:32PM
  Re: i need some free advice.Re: [[ Linda ]] [[ Linda ]] 06/25/08 12:32PM
  Re: i need some free advice.Re: dustin dustin 06/25/08 12:33PM
  Re: i need some free advice.Re: robby robby 06/25/08 12:35PM
  Re: i need some free advice.Re: robby robby 06/25/08 12:37PM
  Re: i need some free advice.Re: Air Bud Air Bud 06/25/08 12:38PM
  Re: i need some free advice.Re: dustin dustin 06/25/08 12:38PM
  Re: i need some free advice.Re: robby robby 06/25/08 12:40PM
  Re: i need some free advice.Re: ben ben 06/25/08 12:45PM
  Re: i need some free advice.Re: [[ Linda ]] [[ Linda ]] 06/25/08 12:45PM
  Re: i need some free advice.Re: Austin Austin 06/25/08 12:48PM
  Re: i need some free advice.Re: Danalog Danalog 06/25/08 12:49PM
  Re: i need some free advice.Re: 🎨🏆 Duncan 🎨🏆 Duncan 06/25/08 12:52PM
  Re: i need some free advice.Re: dustin dustin 06/25/08 12:55PM
  Re: i need some free advice.Re: JunkyardDog JunkyardDog 06/25/08 12:55PM
  Re: i need some free advice.Re: JunkyardDog JunkyardDog 06/25/08 12:57PM
  Re: i need some free advice.Re: dustin dustin 06/25/08 12:59PM
  Re: i need some free advice.Re: Pete Daddeo *YouTube: Moped Problems* Pete Daddeo *YouTube: Moped Problems* 06/25/08 01:07PM
  Re: i need some free advice.Re: robby robby 06/25/08 01:11PM
  Re: i need some free advice.Re: rob farmer rob farmer 06/25/08 01:10PM
  Re: i need some free advice.Re: Zachary Evans Zachary Evans 06/25/08 01:13PM
  Re: i need some free advice.Re: robby robby 06/25/08 01:16PM
  Re: i need some free advice.Re: dustin dustin 06/25/08 01:16PM
  Re: i need some free advice.Re: Zachary Evans Zachary Evans 06/25/08 01:30PM
  Re: i need some free advice.Re: Robert Rosselit Robert Rosselit 06/25/08 02:44PM
  Re: i need some free advice.Re: robby robby 06/25/08 06:40PM
  Re: i need some free advice.Re: sam sam 06/25/08 06:42PM
  Re: i need some free advice.Re: robby robby 06/25/08 06:45PM
  Re: i need some free advice.Re: dustin dustin 06/25/08 06:45PM
  Re: i need some free advice.Re: robby robby 06/25/08 06:46PM
  Re: i need some free advice.Re: §ćŗάτçλmªřċ • §ćŗάτçλmªřċ • 06/26/08 08:46AM
  Re: i need some free advice.Re: Robert Rosselit Robert Rosselit 06/26/08 10:15AM
