Could someone please post an accurate sketch or a photo of what's inside the current-model welded Tomos exhaust pipe?
Tomos stock exhaust
Re: Tomos stock exhaust
No, that's a model from years past. The current style is welded shut so you can't tamper with it. I'm trying to figure out the flow path of the exhaust gases. I've drilled mine through the rear (outlet) hole, with good result, but I want to know how much restriction remains because of whatever is inside.
Tomos stock exhaust
bump
