Moby Bearings/ Mounts
So I'm trying to get my Moby running and want to know if I should replace the engine bearings or grease the wheel bearings? How do I know if they're bad?
Also does anyone know if these are the upper or lower mounts?
http://quarterkick.com/frame/motobecane-engine-mount/prod_25.html
How can I tell if I need to replace those?
Thanks
Re: Moby Bearings/ Mounts
Those are uppers. the lower one is less important as the uppers are what keeps your engine straight
The upper mounts need replacing if they look thrashed and your engine is bouncing around.
The engine bearings are a pretty tough job. If the engine spins freely and sounds good don't worry about it.
same with the wheels do they spin freely and sound nice?
check this site www.mabecanemobylette.com
The manual says I need a special tool to remove the upper engine mounts. Is this true? Is there some other way to do it?
Thanks
You can make a puller out of a large socket. I've got one downstairs, I'll take a piccie tomorrow.
(Thanks to Peter M for the suggestion!)
use the search...I have it printed somewhere will look it up, just be careful...some of the mounting areas are not real strong and those mounts have been in there a long time. Best of luck...this is my summer ped project as well!
