Re: Moteobecane 50v variator...should engage engin
Crackstar X /
Don't use carb cleaner. Use brake cleaner, carb cleaner contains lubricants, brake kleen will leave parts grease and oil slippery stuff free, plus it has a higher pressure spray good for getting greasy stuff out of hard to reach areas.
other areas to check are your belt, a loose belt will slip as soon as the starter clutches try to engage.
