Moteobecane 50v variator...should engage engine?
Hello, first post here, trying to resurrect a 1978 Motobecane 50v. I've fixed seized cabling and rust-filled fuel system, went to make first start attempt, but the engine doesn't turn while pedalling. The "disconnect" on the pedal pulley is in the proper position, and drive belt spins the "outer hub" for the variator, but the internal clutch doesn't spin the engine, totally diconnected no matter how fast i pedal.
How can engine spin while pedalling if the clutch isn't engaging?...I really only have a moderate knowledge of theory of operation of this system, and need help getting the engine to spin while pedalling....and oh, I don't have a puller to yank it off and inspect.
Re: Moteobecane 50v variator...should engage engin
You may want to toss this post up under repair.
But Heres my thoughts, I had this problem today. Your clutch isn't engaging or it isn't gripping the drum well. Either there is oil/grease in the drum causing it to slip or the clutch is damaged/broken. If its just oil/grease in the drum you can usually get by with spraying carb/brake cleaner in there and letting the drippings run out. This will allow you to grip and then start, probably have to do this a few times. If that doesn't work you need to take the cover of the end of variator and inspect the clutch. I think you need a puller to do this and I haven't been able to do it yet, so good luck.
Right on, didn't post under repair since I wasn't sure how it was supposed to operate, and if I was simply doing something wrong. I can hear something clunking inside each time it is rotated back and forth, so can I assume a spring is broken or something like that? I'll try to get a puller. Anyone know where to get one? Anybody local to Santa Cruz, CA want to rent me one?
Do you know about the decompression lever? If not, you need to learn more about Mobys.
Don't use carb cleaner. Use brake cleaner, carb cleaner contains lubricants, brake kleen will leave parts grease and oil slippery stuff free, plus it has a higher pressure spray good for getting greasy stuff out of hard to reach areas.
other areas to check are your belt, a loose belt will slip as soon as the starter clutches try to engage.
I think I have a clutch puller e-mail me
it's more likely that the belt is slipping or your decompression isn't working. But i've seen plenty of seized rusty clutches in my day too, just start with the simple stuff.
I agree I need to learn about this thing first as mentioned about, however, I also have a strong sense of logic. Seeing the belt spinning up the front pulley that it rides on, without spinning up the "clutch housing" where the puller would thread into, and that the right side of engine/flywheel doesn't spin, it 's clearly not a decompression lever issue.
I tried emailing you about the puller, but not sure if it worked. Maybe try emailing me?
cityevader8@yahoo.com
