Re: tecno boss/puch maxi
[[ Linda ]] /
I don't know if there was one there originally or not, but you can make one. You can try this, or you can do what I did: Buy a flat rubber washer that fits in the hole in your carb where it attaches to the intake. Use an exacto knife and cut the middle out of your washer so that the inner diameter on it is about the same size (maybe a little wider) than the hole the air/fuel flows through -- you want it big enough that it's not blocking air flow. Then put that washer into the carb and put the carb back on the intake. It's worked for me on two separate carbs and two separate intakes, although you should experiment with other methods and find out what works for you.
