Re: Fluid Orifices
JunkyardDog /
AZ has the worst emissions tests in the country, much worse than CA. CA does not test anything under a '75, and as far as I know, neither does any other state. AZ goes all the way back to '67. And '67-'80 cars are almost impossible to get to past the test. You have to lean them out to the point where they barely run, get them tested, then retune them to be drivable. But you will never get any serious power out of them. For popular classics like Mustangs, Vettes, air cooled VW's, etc. that makes a '66 model worth a lot more than a '67. I could drop a blown 427 with 2 Holley 850 double pumpers on a tunnel ram topped off by a Hilborn scoop sticking 2' up through the hood, with headers and Cherry Bomb glasspacks into my Fairlane, and be perfectly legal. I knew one guy, back when I was into air cooled bugs, that had 2 engines for his early '70s bug. He kept an extra engine just to pass emissions with, them swapped them out after passing the test. He had it down to where he could do an engine swap in about an hour. That's one of the things that makes mopeds so much fun, being under 50cc, they are also emissions exempt, You can rip the catalytic pipe off of a new Tomos, richen it up good, and not have to worry about an emissions test. Rust free pre '67 cars are very expensive around here, because you can do anything you want with them. A lot of local amateur racers drive their pre '67 cars to the track, run a 10 sec. E.T., then drive them home. The ones with late model race cars have to trailer them to the track and back. Tree huggers need not respond. Peace. Jerry.
  Tomos oil injectionTopic by: JunkyardDog JunkyardDog 06/17/08 11:27PM
  Re: Tomos oil injectionRe: [[ Linda ]] [[ Linda ]] 06/18/08 12:45AM
  Re: Tomos oil injectionRe: terry dean terry dean 06/18/08 01:09AM
  Re: Tomos oil injectionRe: Crackstar X Crackstar X 06/18/08 01:28AM
  Re: Tomos oil injectionRe: toe fur threadkiller toe fur threadkiller 06/18/08 01:29AM
  Tomos oil injectionRe: Brennan O. Brennan O. 06/18/08 08:42AM
  Re: Tomos oil injectionRe: bub bub 06/19/08 11:43PM
  Re: Tomos oil injectionRe: Scott Scott 06/18/08 12:24PM
  Re: Tomos oil injectionRe: JunkyardDog JunkyardDog 06/18/08 01:48PM
  Re: Tomos oil injectionRe: Daniel Van Donsel Daniel Van Donsel 06/18/08 02:41PM
  Re: Remember to fill your reservoirRe: Moped Jay Moped Jay 06/18/08 12:55PM
  Re: Remember to fill your reservoirRe: ▣ß@ηℊℙℐṔ∃▣ ™ ▣ß@ηℊℙℐṔ∃▣ ™ 06/18/08 12:57PM
  Tomos oil injectionRe: Dustin Medina Dustin Medina 06/18/08 01:48PM
  Re: Tomos oil injectionRe: terry dean terry dean 06/18/08 02:57PM
  Re: Tomos oil injectionRe: JunkyardDog JunkyardDog 06/18/08 05:23PM
  Re: Tomos oil injectionRe: Seattle Tony Seattle Tony 06/18/08 05:34PM
  Re: Tomos injection good - JerryRe: Seattle Tony Seattle Tony 06/18/08 05:55PM
  Re: Tomos oil injectionRe: [[ Linda ]] [[ Linda ]] 06/18/08 06:47PM
  Re: Tomos oil injectionRe: terry dean terry dean 06/18/08 07:11PM
  Re: Tomos oil injectionRe: John Joedicke John Joedicke 06/18/08 09:17PM
  Re: Tomos oil injectionRe: Vimy Ridgeway Vimy Ridgeway 06/18/08 09:44PM
  Re: Tomos oil injectionRe: steve steve 06/18/08 07:12PM
  Re: Tomos oil injectionRe: Aj Aj 06/18/08 08:01PM
  Re: Tomos oil injectionRe: Raymond Wright IV Raymond Wright IV 06/18/08 09:19PM
  Re: Tomos oil injectionRe: andrewhed andrewhed 06/18/08 11:18PM
  Re: Tomos oil injectionRe: JunkyardDog JunkyardDog 06/19/08 12:09AM
  Re: Tomos oil injectionRe: nitronick nitronick 06/18/08 11:45PM
  Re: Tomos oil injectionRe: keller_stephen keller_stephen 06/19/08 05:05AM
  Re: Tomos oil injectionRe: Andrewhed Andrewhed 06/18/08 11:59PM
  Re: Tomos oil injectionRe: Andrewhed Andrewhed 06/19/08 12:30AM
  Re: Tomos oil injectionRe: JunkyardDog JunkyardDog 06/19/08 12:45AM
  Re: Tomos oil injectionRe: Andrewhed Andrewhed 06/19/08 12:52AM
  Re: Fluid OrificesRe: black twingle black twingle 06/19/08 05:01PM
  Re: Fluid OrificesRe: JunkyardDog JunkyardDog 06/19/08 08:51PM
  Re: Fluid OrificesRe: andrewhed andrewhed 06/19/08 09:15PM
  Re: Fluid OrificesRe: JunkyardDog JunkyardDog 06/19/08 09:26PM
  Re: Fluid OrificesRe: andrewhed andrewhed 06/19/08 09:58PM
  Re: Fluid OrificesRe: JunkyardDog JunkyardDog 06/19/08 11:34PM
  Re: Tomos oil injectionRe: bub bub 06/19/08 11:39PM
  Re: Tomos oil injectionRe: Scott Scott 06/19/08 11:50PM
  Re: Tomos oil injectionRe: Bad Adam Bad Adam 06/19/08 11:55PM
  jerry's injectionRe: JJW JJW 06/20/08 09:59AM
  Re: Tomos oil injectionRe: Josh Josh 03/12/10 05:16PM
  Re: Tomos oil injectionRe: Josh Josh 03/12/10 05:25PM
  Re: Tomos oil injectionRe: tweeder tweeder 03/12/10 05:35PM
  Re: Tomos oil injectionRe: Mike Mike 03/12/10 05:58PM
  Re: Tomos oil injectionRe: russg russg 03/12/10 06:31PM
  Re: Tomos oil injectionRe: juneaujim juneaujim 03/15/10 03:35AM
  Re: Tomos oil injectionRe: Future303 Future303 06/01/10 09:15AM
  Re: Tomos oil injectionRe: Air Bud Air Bud 03/15/10 03:46AM
  Re: Tomos oil injectionRe: Deathproof Doug Deathproof Doug 06/01/10 09:40AM
