Re: My fast Pinto
Sue Nichols /
_yes Rafter is awesome, i love him. but, lets also give some love and respect to moto matics own Nathan Kiehn as well, he is our true unsung hero who does waayyyyy more for mopeds and our own gang than anyone i know. Mike and Nate are a duo and incredible people, don’t forget_
Absolutely. I just didn't know who all to thank. So also a huge thanks to Nate. The craftsmanship is amazing. When I bolted it on the fit was perfect.
_You dont get to go that fast by buying a new pipe._
So here is the setup:
80 metra-case matched.
19mm Dellorto carb
3 shoe clutch
stuffed race crank
moto matic 8p
A huge amount of time went into this and I am extremely happy with how it has turned out. I can hardly believe that I can go 64mph on a moped.
As for carbs, the Dellorto manual states:
-A larger sized carburetor generally allows more power at high rpm ie. a higher maximum speed. However, simply fitting just a larger carburetor may not bring about the desired increase in power output as this often only follows from several additional engine modifications, each designed to improve some other aspect of the engine's performance.
-A smaller carburetor will give better pick-up and therefor in selecting a choke size, you should always balance your power and acceleration requirements.
I started out small, and even with the 18x36 gearing and the pipe i have a good bit of bottom end left that I am willing to sacrifice for more top end. That has been my method on this entire build. I've been conservative on everything and then upgrade from there. Now I am amassing bits and pieces that I will be able to use on a different, less extreme build.
Dylan--We miss you too!!!
Lori -- Thanks. I couldn't stop laughing. This is insane!
The tank is mounted thru the frame with threaded rod and nuts.
  My fast PintoTopic by: Sue Nichols Sue Nichols 06/17/08 10:38PM
  Re: My fast PintoRe: SABAT! andDestroy SABAT! andDestroy 06/17/08 10:40PM
  Re: My fast PintoRe: Jake Mesa Jake Mesa 06/17/08 10:41PM
  Re: My fast PintoRe: mike mike 06/17/08 10:42PM
  Re: My fast PintoRe: Sue Nichols Sue Nichols 06/17/08 10:46PM
  Re: My fast PintoRe: Jake Mesa Jake Mesa 06/17/08 10:57PM
  Re: My fast PintoRe: Tim Tim 06/17/08 11:26PM
  My fast PintoRe: travis travis 06/17/08 11:30PM
  Re: My fast PintoRe: Tyler Jacobson Tyler Jacobson 06/18/08 01:30AM
  Re: My fast PintoRe: Gone Away Gone Away 06/18/08 01:41AM
  Re: My fast PintoRe: mike mike 06/18/08 01:43AM
  Re: My fast PintoRe: Timmy Southpark Timmy Southpark 06/18/08 01:44AM
  Re: My fast PintoRe: Sara K Sara K 06/18/08 01:50AM
  Re: My fast PintoRe: rafter rafter 06/18/08 02:30AM
  Re: My fast PintoRe: keller_stephen keller_stephen 06/18/08 03:07AM
  Re: My fast PintoRe: DyLaN DyLaN 06/18/08 03:09AM
  Re: My fast PintoRe: Zack Zack 06/18/08 03:15AM
  Re: My fast PintoRe: Andy Andy 06/18/08 04:44AM
  Re: My fast PintoRe: Kansas John Kansas John 06/18/08 05:17AM
  Re: My fast PintoRe: finny finny 06/18/08 05:54AM
  Re: My fast PintoRe: Sue Nichols Sue Nichols 06/18/08 11:25AM
  Re: My fast PintoRe: weeder weeder 06/18/08 11:39AM
  Re: My fast PintoRe: Sue Nichols Sue Nichols 06/18/08 11:50AM
  Re: My fast PintoRe: Graham Motzing Graham Motzing 06/18/08 11:59AM
  Re: My fast PintoRe: Responsible Jon Responsible Jon 06/18/08 12:23PM
  Re: My fast PintoRe: Broberto Broberto 06/18/08 12:38PM
  Good Job!!!!Re: Elder Bandit Elder Bandit 06/18/08 01:08PM
  Re: Good Job!!!!Re: Broberto Broberto 06/18/08 01:36PM
  Re: Good Job!!!!Re: Gone Away Gone Away 06/18/08 01:37PM
  Re: Good Job!!!!Re: kate kate 06/18/08 02:12PM
  Re: Good Job!!!!Re: Elder Bandit Elder Bandit 06/18/08 02:22PM
  Re: Good Job!!!!Re: Sue Nichols Sue Nichols 06/18/08 02:41PM
  Re: Good Job!!!!Re: Elder Bandit Elder Bandit 06/18/08 02:46PM
  Re: Good Job!!!!Re: corey c corey c 06/18/08 03:16PM
  Re: Good Job!!!!Re: peter peter 06/18/08 03:18PM
  Re: Good Job!!!!Re: dallas dallas 06/18/08 04:11PM
  Re: Good Job!!!!Re: §ćŗάτçλmªřċ • §ćŗάτçλmªřċ • 06/18/08 04:54PM
  Re: Good Job!!!!Re: Sue Nichols Sue Nichols 06/18/08 04:59PM
  Re: Good Job!!!!Re: travis travis 06/18/08 05:05PM
  Re: Good Job!!!!Re: homoped homoped 06/18/08 05:11PM
  Re: Good Job!!!!Re: Gone Away Gone Away 06/18/08 05:50PM
  Re: Good Job!!!!Re: Sue Nichols Sue Nichols 06/18/08 05:51PM
  Re: Good Job!!!!Re: Gone Away Gone Away 06/18/08 05:52PM
  Re: Good Job!!!!Re: steve steve 06/18/08 06:36PM
  Re: Good Job!!!!Re: derek derek 06/18/08 06:44PM
  Re: Good Job!!!!Re: King Drunky JCams King Drunky JCams 06/18/08 07:06PM
  Re: Good Job!!!!Re: Chris Squid Chris Squid 06/18/08 09:44PM
  Re: Good Job!!!!Re: Air Bud Air Bud 06/18/08 10:57PM
  Re: My fast PintoRe: Corey Corey 06/19/08 10:12PM
  Re: My fast Pinto--updateRe: Sue Nichols Sue Nichols 07/23/08 02:21PM
  Re: My fast Pinto--updateRe: Bad Adam Bad Adam 07/23/08 02:25PM
  Re: My fast Pinto--updateRe: mike mike 07/23/08 02:27PM
  Re: My fast Pinto--updateRe: Elder Bandit Elder Bandit 07/23/08 02:38PM
  Re: My fast Pinto--updateRe: Air Bud Air Bud 07/23/08 02:43PM
  Re: My fast Pinto--updateRe: jack jack 07/23/08 03:40PM
  Re: My fast Pinto--updateRe: noah noah 07/23/08 04:24PM
  Re: My fast Pinto--updateRe: Freebird Freebird 07/23/08 05:10PM
  Re: My fast Pinto--updateRe: mike mike 07/23/08 05:26PM
  Re: My fast Pinto--updateRe: nele nele 07/23/08 05:40PM
  Re: My fast Pinto--updateRe: nele nele 07/23/08 05:41PM
  Re: My fast Pinto--updateRe: Freebird Freebird 07/23/08 05:45PM
  Re: My fast Pinto--updateRe: jack jack 07/23/08 06:08PM
  Re: My fast Pinto--updateRe: mike mike 07/23/08 06:20PM
