lifan engine 110cc
jason joel harris /
has anyone had any problems installing an after market lifan engine on a honda cub/ca100/102. i looks as though you have to shave the frame a little bit to get the hole pattern to match up. has anyone made this conversion. please advise -j
Re: lifan engine 110cc
Dunno about that...I had to shave the holes on my stock bracket to fit an aftermarket exhaust, which was a pain...l
Maybe dratv.com can help!
http://www.dratv.com/newreen.html
They're out of stock at the moment, but that's not common from what I've seen. Looks like it's cheaper too...hope that helps!
jason joel harris /
thanks for the info. yeah, i saw that site but i have the a different problem where the the back engine hole is below the frame mount hole. in looks like if i pivoted off of the top engine bolt and shaved the frame a little bit to acomadate for the slightly different engine shape, it might work. thanks for the quick response. any other suggestions.
