Re: do you guys wash your mopeds?
[[ Linda ]] /
Yup, often. I thought I was meticulous, but I wouldn't eat off the inside of my fenders.
You can remove some dirt and dust with a bucket of soapy water and a rag. Keep it away from the electricals though. Once you get the major goop off:
Carb cleaner is good for getting stuff off metal parts, and degreaser (I have some sort of orange stuff) is good for the rest. Don't let it sit for forever on the paint, though. If the goop is really heavy, scrape it off gently first, then break out the chemicals.
A long skinny screwdriver is good for scraping heavy goop off (just be careful not to scratch anything except the goop) in tight places.
Terry cloth towels are good for soaking stuff up and cleaning easy-to-reach areas. Cut up t-shirts are good for getting in smaller nooks and crannies. If it's an extra-small nook or cranny, use your screwdriver to push the rag into it and wipe away all the glop.
Q-tips are just good in general, as are old toothbrushes.
0000 (extra extra fine) steel wool is good for cleaning chrome.
When you take something apart, clean it thoroughly before putting it back together. Spraying down nuts and bolts with carb cleaner or letting them soak in CLR for a few minutes will help clean them up, but make sure to dry them off well (if you use CLR) or else they'll rust back up again.
  do you guys wash your mopeds?Topic by: b b 06/17/08 12:24AM
  Re: do you guys wash your mopeds?Re: 🎨🏆 Duncan 🎨🏆 Duncan 06/17/08 12:30AM
  Re: do you guys wash your mopeds?Re: Seth Bedwell Seth Bedwell 06/17/08 12:31AM
  Re: do you guys wash your mopeds?Re: triumph3434 triumph3434 06/17/08 12:33AM
  Re: do you guys wash your mopeds?Re: MadtownMick MadtownMick 06/17/08 12:36AM
  Re: do you guys wash your mopeds?Re: triumph3434 triumph3434 06/17/08 12:40AM
  Re: do you guys wash your mopeds?Re: shoelace shoelace 06/17/08 12:42AM
  Re: do you guys wash your mopeds?Re: [[ Linda ]] [[ Linda ]] 06/17/08 01:53AM
  Re: do you guys wash your mopeds?Re: Andy Andy 06/17/08 04:00AM
  Re: do you guys wash your mopeds?Re: michael moore michael moore 06/17/08 01:26PM
  Re: do you guys wash your mopeds?Re: Broberto Broberto 06/17/08 01:30PM
  Re: do you guys wash your mopeds?Re: Monty Jardine Monty Jardine 06/17/08 02:50PM
  Re: do you guys wash your mopeds?Re: Air Bud Air Bud 06/17/08 02:51PM
  Re: I'd rather wash my armpitsRe: Andy Andy 06/17/08 03:34PM
  Re: do you guys wash your mopeds?Re: Brandon Brandon 06/17/08 04:33PM
  Re: do you guys wash your mopeds?Re: Nash . Nash . 06/17/08 04:44PM
  Re: do you guys wash your mopeds?Re: toe fur threadkiller toe fur threadkiller 06/17/08 06:27PM
  Re: do you guys wash your mopeds?Re: jonvdb jonvdb 06/17/08 06:33PM
  Re: do you guys wash your mopeds?Re: Air Bud Air Bud 06/17/08 06:46PM
  Re: do you guys wash your mopeds?Re: toe fur threadkiller toe fur threadkiller 06/17/08 06:47PM
  Re: do you guys wash your mopeds?Re: SpartaFoxiLover SpartaFoxiLover 06/17/08 09:57PM
  Re: do you guys wash your mopeds?Re: Air Bud Air Bud 06/17/08 10:54PM
  Re: do you guys wash your mopeds?Re: Ben Van Zoest Ben Van Zoest 06/17/08 10:21PM
  Re: do you guys wash your mopeds?Re: JunkyardDog JunkyardDog 06/17/08 10:54PM
