can you run pre-mix in an '82 express?
i know these have forced lubrication, does that mean pre-mix would be a bad idea or fuck it up? my oil tank is leaking now and i'd rather just get rid of it altogether.
Re: can you run pre-mix in an '82 express?
Yes, just block of the line going to the carb/intake, loop the pump ports, and remove the pump drive shaft.
cool, thanks.
Premix is a great idea. And, it's proven to work. Peace. Jerry.
Just took the injector off of my MB5 ratbike tonight-- no worries about pump failure now.
Have you outfitted your Express with floatation devices to get around IC?
haha, im actually in the process of moving back to des moines, all my bikes are here right now. i should come out to ames sometime!
not to be all targaped here or anything, but i've never had a honda oil injector fail on me...or heard anything bad about them.
that said, if i buy a 2008 sprint, my first project will be removing the oil injector.
Want to reply to this thread?
